The cool part about the vid ids the rest of us will not only be entertained but it helps us diagnose any issues you might have to give you the best chance to fix it, whether it is the plane or the piloting. That is a great idea. Have you got a sim to play with until the weather cooperates? Those help improve the stick skills on the off times, helps develop muscle memory for the real thing.As the thread title implies I have very little stick time. I expect to crash. I just want to give myself the best chances for any kind of flight however short it may be. Just trying to not build a lawn dart or a rocket to the moon. I will definitely Take your advice BATTLEAXE. As soon as we get a nice day I'm going to maiden it and probably beat it up lol. I will put up a vid for everyone to have a chuckle because it's bound to be funny!
I've built 2 P-40s, have over 100 flights on them.......and yes it is a big deal (at least to me, not so much for others). Anyone who has read any of my post knows I'm obsessed getting the cg right.@Marty72 - where does your P40 balance? This is kinda a big deal.
I've built 2 P-40s, have over 100 flights on them.......and yes it is a big deal (at least to me, not so much for others). Anyone who has read any of my post knows I'm obsessed getting the cg right.A plane with a perfectly located cg flies amazing, a little forward or back and it flies but just not as well IMO. The CG location I've settled on with the 1st P 40 was 1.75 inches (2.0 spec), the cg on the 2nd P 40 works best at 1.50 inches. I would suggest for a beginner using a slow fly prop, spec motor, in the range of 1.5 to 2.0 inches fwd of the LE for the first flight. I don't know why .5 inches is suggested in the video, but I believe that's bad data. The plans and the FT website both say 2.0, and that's in writing. That's what I used as a guide. BTW, I've settle on a cg slightly ahead of the spec cg for all the FT Warbirds I've built (P40, P51, Spitfire). Will a .5 cg off the leading edge fly, I don't know, but I'd be surprised if it flew well.
After the first flight, you can adjust cg as needed. If you take video, you'll be better able to access what really happened (if things don't go well). You can learn a ton from a video as a beginner (because you senses will be over loaded).
Battleaxe is right on, 100% correct as usual, on his above statements. Yes, a beginner is a little better off with the cg a tad back, faster fliers like cg a tad forward. As speed increase, cg needs to move forward a bit. I run a larger motor and prop than spec (1200 35-36 rimfire w/ 10x7 prop). I've also have many flights with the "c pack" motor (9x6 prop) and it works fine, it just doesn't have the vertical capability of the Rimfire.
2nd P 40
BTW, for balancing, I use nickels, 5 grams a piece. I glue inside the foam walls if needed.
Thats the spirit. More crashing develops the building skills. Its a win/win to crashingThanks man!! This is good news as my plane wants to be slightly nose down at like 2" to1.75" from the LE. Come on sunshine!! Daddy got a plane to crash.
Congrats! Actually that was pretty dam good. Really good! Remember - altitude and throttle cut are your friends.
Wow! that went really good for a first time. I'm glad you decided to go without landing gear, planes survive crashes way better without gear.
You also did something else good, having someone else launch the plane. On my first attempts, I did the hand launch and was trying to get my hands back to the sticks. It gets you behind the curve, and sets you up for failure.
You did a great job getting off the throttle when you were about to crash. You saved the plane by doing that.
After watching the videos, the plane looks like it flies well slow, which is great for learning. My advise is to get that plane up high and just try and stay up. It's tough to trim when you are new at this, I crashed a few times trying in the beginning.
Remember, the longer you stay up, the more you learn. So next time, get the plane up high, way up...this will give you more options.
Thanks @Marty72. High praise coming from someone with far more experience! Yeah I wasn't about to try and launch myself, I knew it would go bad lol. Only reason I went with no gear is where I fly is tall grass that would rip it off I figure. Now that I have some advise on the gear I'll leave it off. The wind pushed me around a bit but I found my ailerons super touchy even with 50% expo! Next time I'll try to stay higher for sure. Thanks again man!
I watched the videos again. You need about half throttle to fly this plane (of course, I can't be sure how you tx is set). The last video, you didn't have enough speed and you were fighting a stall (you probably already know this).
Check all the control surfaces and make sure the power pod is in there secure before launching again. The plane is in amazing shape for 3 crashes. You are on your way, just get altitude next time!
I may have more experience but I started flying in October of 2019, so still remember what it is like to be a rank beginner.
The ailerons were a problem for me as well, my first 7 flights, I got a total of about 7 minutes of flight time. The 8 flight and I stayed up for full time. It was awesome.
Ailerons: expo is great but you can reduce the throw on them in the TX and you should. You don't need all that authority now. I'd take it down to at least 70%, you could probably go as low as 50% and be fine. The thing that made me crash, was overly sensitive ailerons. If you can set up low, med and hi rates on your TX, I would. If that's the case, use 50% for low, 70 % med and 100% for high. 50 % expo if fine right now.
I'm going to repeat myself again, Elevation, elevation and elevation. I did the same thing as you and I had people telling this, it's not easy, but it's what you need to hear.
