greencardigan
Hi all,
This is my first adventure into the RC world and I've decided try building a V-tail quad. I'd appreciate any thoughts and guidance as I learn and build.
I've already rushed in and bought some stuff from hobby king. Let me know if I've made any bad choices.
I'll be building the frame from ply and 10mm square timber sourced locally.
4 x Turnigy D2836/8 1100KV Brushless Outrunner Motor ( AUS Warehouse )
2 x Slow Fly Electric Prop 9047SF (4 pc) - 9 x 4.7 - I bought these when I was planning to use the DT750 motors. Hopefully they will be ok with the motors listed above
4 x Hobby King 30A ESC 3A UBEC (AUS Warehouse) - will flash with simonk firmware
4 x Hobby King 20A ESC 3A UBEC - I realised these might be too small so I ordered the 30A ones later
1 x Turnigy 3300mAh 4S 30C Lipo Pack (AUS Warehouse)
2 x Turnigy 3000mAh 4S 20C Lipo Pack - I realised these might be too small so I ordered a 30C pack later
1 x Hobbyking KK2.0 Multi-rotor LCD Flight Control Board - will flash with the latest firmware to get v-tail support
1 x Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware)
1 x Turnigy 9X 2.4GHz 8Ch Receiver (V2)
1 x Turnigy Accucel-8 150W 7A Balancer/Charger
1 x Atmel Atmega Socket Firmware Flashing Tool
1 x Front Wheel Steering Arm & Mount Set 40mm (5sets) - was originally going to use these in a tricopter build
2 x 10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set)
1 x XT60 to 3 X 3.5mm bullet Multistar ESC Power Breakout Cable - was originally going to use these in a tricopter build
1 x HXT 4mm to 4 X 3.5mm bullet Multistar ESC Power Breakout Cable
1 x Hex locknuts M4 10pc
1 x 20CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) - was originally going to use these in a tricopter build
2 x PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
