Anyway enough frivolity.
I managed to finish painting the F22 Mk1 while I was off and checked the CG, which is okay. It still needs some varnish and a new cowl to finish it off properly though.
I've also started work on the Edge, stripped the Motor and ESC out to begin with. The F1 former is the only part that's damaged, unfortunately due to the design I have to remove the cowl to get access and replace it. I initially considered just bracing it from front and back with ply and using something like gorilla glue as an adhesive, but getting to the front of the former is difficult as access is cramped through the cowl.
So its looking like I will have to remove the cowl completely, just so I can replace the former with either: an alternative version consisting solid Plywood or a laminated version with a thin plywood backing. As the cowl is glued to the side panels of the fuselage they will suffer during the cowl removal, so they may need replacing or repair too.
Its a pain but its got to be done, I wont be happy doing a half arsed repair on it.
