FOAMSLAYER
any good ez pack designs on the forum recommendations?
Thanks, its very underpowered tho so I need to work on that.
Yeah thats good idea. Still got quite a bit of work to do..I think so... That way we can see more detail and come back to it for references. I've always thought of this thread as a, "I've finished".
In the future, digging out five posts that might be among the 1000+ pages will be near impossible.
My EZ Bronco is a fun one. Takes ¼ piece of foam and comes together in 6 pieces. It also has a silly skin if you like that sort of thing.any good ez pack designs on the forum recommendations?
Epic little flyer and sounds sweet tooThanks! It’s a bit rough close up, but I’m pretty pleased with it! The white backing is just sticky vinyl hand cut with the kitchen scissors.
Maiden happened last week - without canopy and decals. It’s my first EDF so I was fairly nervous, but it went fine. Even the dreaded hand launch…
Flew this morning complete with canopy and decals so I’m calling it “done”.
Proof of flight below from flight number two on maiden day against dull grey skies. I’m going to try and get better video when we get some nicer weather!
Paper on, mostly. I only scaled the slots and did have some fit issues. Mostly with the firewall mounting. Which, I'm thinking was the main reason I had a dismal maiden experience.Nice. I was just out fooling around with mine yesterday. Did you do your paper on or off? Did you scale it to fit DTFB or adjust the slots?
This was my first time flying a pusher. First time flying an Elevon plane. First time adjusting plans to fit DTFB. A lot of firsts and, as I said, a dismal failure.
Hah! Do things logically? Me? Right...
I did check and recheck CG in between my 3 miserable "flights". It was consistently slightly nose heavy with a finger tip test on the CG slots. I do think the battery moved during the last, fatal flight.
You will love the Spitfire. It's a joy to fly.Evidently, I forgot to hit the post button! This was from last night.
I put the FT Spitfire together today. Ready for electronics.
I didn't take any detail pics before the maiden.Ooh dear, sorry to hear that went so awry, I designed this thing specifically to avoid such mishaps. It is certainly eliciting a tail-heavy characteristic, despite your reports of it being nose-heavy. Then again, with mine, I cannot get it to be any less nose heavy than just about balancing on the leading corners of the notches, but even then, this plane is meant to be steady on the pitch and the CoG is indeed supposed to be gradient.
I'm surprised your motor came up too short, it's designed to use an Emax racing quad motor, can you supply a close up pic of your motor mount arrangement? I'm wondering if I can spot any issues there.
Basically, the rear of the upper and lower fuse did not line up with the rear edge of the motor mount vert. insert. The foam backing on the 3D printed mini firewall was glued to the X created by the wing and insert. No perimiter support. It looked(to the naked eye) like it was straight and square to the assembly, but I'm sure there was a good bit of flex there. The prop looked to be in the correct position, i.e., centered in the slot area.
I was running a 3S 1300mAh battery and had to push it back as far as it would go to not have it super nose heavy. Of course, I was just using my finger tips as a balance and may have been at the back of the slots rather than the middle or front.
I do plan on cutting another soon and trying again.
I've got a couple 4S 850s. and some 2S 650s, I think.
