So I tried something new!
The tail of my build was getting a little beat up and mushy. Originally I was going to just build a new fuse but I thought "why not do something out of the ordinary." I've always wanted to build a Zlin Savage bobber so I decided to build something like one of those. I only have bbq skewers so I was a little concerned about weight right off the bat. I started by amputated the tail right where the fuse starts to taper.
I started off by tracing the side profile of the fuse onto a sheet of paper. I put a piece of cardboard under the piece of paper and some wax paper above it. The cardboard was so I could stick pins into it to keep the bbq skewers aligned, and the wax paper was to stop glue from sticking to the paper. I then began the process of glueing all the bbq skewers together.
I was originally expecting to not use cross bracing, but I like the look of them and it could use a bit of stiffness.
After I finished the first half I built the second but made it so the cross braces pointed in the opposite direction of the first half.
I then began the slightly irritating process of connecting the two halves together. Luckily I had some thin CA so I was able to tack everything in place before filling the gaps with wood glue to make a solid joint. I took my time and everything was perfectly square and centered.
Next I cut out new tail feathers because the old ones were getting pretty tired. I got rid of the counterbalances on the elevator because the old ones would get caught in the grass and tear them up whenever I flared the plane during a landing. I chose not to iron the tail feathers because I like the rugged look it has and because it annoys
@BATTLEAXE I then painted the wooden part black and the tail feathers orange to add some color.
I then mounted the tail section onto the main fuse. I wanted the service to be unseen so I mounted them in the fuselage. Typically I paint the pushrods and control horns the same color as the surrounding fuse. I wanted to try something different so I elected to paint the whole pushrod system silver to kinda replicate the shiny exhaust headers you find on antique restored cars and motorcycles. In the end I'm very happy with the result!! The modification added 1.3 grams of weight, which could be neglected if I didn't paint it.
The remaiden went great! There was a little bit more flex in pushrods because they were longer so there was a tiny bit less authority when the servo had to push the control surface. Other than that there was no noticable change in flight characteristics.
