Cyberdactyl
Misfit Multirotor Monkey
You're welcome.
Two tips I would offer.
One is, be careful putting the epoxy between the wire leads and the aluminum bearing housing. If you get it too much and too high on the housing, you'll have a heck of a time getting the motor stand pushing on. You'll have to trim the epoxy away.
Second if you use JB WELD, insure you have the bell and stator separated, and you let it cure/dry before reassembling. JB WELD is magnetic and it WILL propagate to the bell's magnets and bridge across. Believe me, I learned the hard way, and spent 15 minutes on each motor chipping away that bridge and cleaning the bell's magnets with the tip of an exacto.
