I plan to put an Aura 5 in a Flying wing with the card mounted on the bottom side of the wing. The means that card will be upside down and only accessible from the bottom side of the wing. I have two questions
1) When I power up the electronics should I keep the plane horizontal, level, and upside down or should I power up and then quickly rotate the plane so it in a right side up orientation.? I know the Aura board will fail its start up configuration if moved during the boot up, hence the issue with rotating the plane to the correct orientation on powered up. If I leave it upside down, will it know the plane was upside down at boot up and have the correct orientation for flight?.
2) Similar to my first question, is the plane orientation important when I activate the Launch assist
Dave
Dave
