Well, this should change your mind ;-) I realized when I drilled the wing mounting holes, i screwed the measurement up so they’re not centered. Crap....I don’t know how I missed a 1/4 inch, but I sure did. It’ll bother me forever.
<EDIT> Okay, it bothered me too much so I took it apart, doweled the mis-drilled hole, filled the sheeting in and redrilled the whole thing. Once it's painted, the different tone balsa won't show and the holes are now correct. Maybe I can sleep now ;-)
Here's a couple tips though...not that my error gives much confidence in my abilities. Rather than sheet the top of the cockpit the way they describe and using triangular pieces to fill in, I took a carrier sheet and grabbed the top profile of the wing rib from it. I sanded it to fit the beveled contour and cut the sheeting using that as a template. That way I didn’t have to do a lot of filler pieces.
When you get to the tail, it has you glue the vertical stab in place, then shape the two triangular filler blocks to shape. I did it their way and it’s a pain. I think an easier way would be to use a 1/4” spacer where the stab would go, then tack glue the blocks in place. This would let you carve/plane the blocks to shape without the stab being in the way. Their way forces you to carve, check it, carve more, check it, sand, check it, etc. I’d rather tack it in and carve to shape, then remove, glue the vert stab and then the pre-shaped blocks.
just a thought...
