First time balsa builder here, long time lurker on this forum, figured I'd give it a shot.
Actually, this is the first time I've even touched a plane or kit in over a year now, so I do kind of feel like a novice at it again. I've been wanting to get back into it again for a few months, but my other hobby (shooting and reloading) had taken over the workbench to the point there was just no room for balsa. To get rolling again I'm starting with an "easy" kit that I've had for a couple years. Well, there are actually TWO of these kits in the box except for the wings (which were built when I got the kits). I know there are a couple pieces missing, but it's a safe bet that at least 90% of the parts are here. The nice thing about the Kadet design is that it's mostly just stick-built, so missing parts are easy to reproduce.
The plan is to go with a small gas engine, probably 9cc. It will be a good companion to my electric Kadet Senior which is powered by a 5 cell setup. The big hurdle will be finding where I put all my tools over the past year!
A little sorting tells me I've got at least enough parts to build one complete fuselage. To build the second will require custom cutting a few pieces or buying the missing parts direct from Sig.
Here's one of the two wings I got with the kits. The other is already joined together as a full wing, and neither is in great condition. This wing is better than the other, and both COULD be used with a little fixing. However, my plan is to add ailerons to this build and flatten out some of the dihedral, so I'm probably just going to order a new wing kit from Sig and incorporate the changes from the start. Maybe I'll build one of the old wings up so I can run the plane as either 3 or 4 channels just by picking the appropriate wing.
