I'm just going to come right out and say it - when it comes to holding batteries in planes, hook and loop fastners (aka velcro) are the debbil.
Put on a few flights in the cold this morning (below freezing with the wind chill). My hands were numb and clumsy and I ripped the whole battery tray out of my balsa Ugly Stick when I was disconnecting the battery.
And this isn't my first run in with velcro either - I've tore velcro straps out of planes left and right, had sticky velcro peel off planes at the field, and have generally grown to hate the stuff.
So instead of gluing the battery tray back in with new velcro straps into my Ugly Stick, I want to come up with some other design to hold the battery in the right place. Design requirements as follows:
I was able to come up with a good solution for my balsa Cuda. I padded the insides and front of the nose with 1" foam insulation that a 3s2200 slides firmly into, with another little block of foam I push in behind the battery to lock it in place once it's loaded. A drawback is no airflow to reduce heat, but I've never had a problem with batteries coming down warm in that plane before or since.
So what do ya'll think? I might try something similar for the Ugly Stick, possibly with some channels cut for airflow, but I'm really hoping other folks on the forums have some other examples or great ideas.
Help!
- It should be simple to load and unload a battery.
- It should not require tools to operate.
- It should prevent the battery from moving around in flight or on landing.
- It shouldn't add significant weight to the airplane.
Help!
