The EDFs are a skill in and of their own to fly. You've got to have a fair amount of room to land the smallest ones; the guys at my field who have skill and experience use all of our available 600' runway to land on when bringing down an EDF plane; you generally can't just "chop the throttle" and glide it in; do that, and it'll be like trying to land a brick with wings.
The easy flying planes that you've probably flown before are likely things that have gyros on them, the "toy" grade planes that don't take much to fly. One of the big clues for those is that they won’t roll into a barrel roll or do loops; the gyro will limit its action to keep it to where you can fly it smoothly.
If you’ve honestly not flown an actual RC plane (and by that, I mean something that would likely be found at a hobby shop as opposed to the toy aisle at Walmart or Target) I would suggest something more in line with a Tiny Trainer, Storch, or Bushwacker. Learn to fly that smoothly, then move up to a warbird like the FT Mustang, or the MiG-3, before you move up to an EDF. Learn to land a warbird, because you generally need to bring those in a little faster for landing so they don’t stall on the landing and you end up with a wrecked plane.
If you’re really dead set on an EDF, you can go get yourself one, but it’s going to be expensive. Expensive for the transmitter, expensive for the battery and charger (there aren’t many chargers that can charge 6S batteries, which are commonly used for EDFs), and lastly, expensive when it crashes if you’re not an experienced pilot.
I say this all, not because I want to discourage you from flying, but because I don’t want you to think you threw away several hundred dollars on something that lasted for 30 seconds in flight before it has a potentially bad landing. I’d rather have you crash a cheap foamie that costs you less than $10 to rebuild anew numerous times before you step up to an EDF that will run you $250 just for the plane (and I think that’s being conservative on the cost).
