Best ft trainer withc pack
kdobson83
The Simple Storch comes to mind. You could put flaps on it and even leading edge slats and it'll fly at walking pace. That's a lot of motor and prop tho.
Watch https://youtu.be/h_WwwWZSjhU
This is the FT video on it.
The scout would be a good option as well but wouldn't fly as slow as the Storch.
kdobson83
Oh, and what battery you using? That 12x6 prop on that motor is listed for 2s. You'd want a 10x4.5 or something on 3s.
kdobson83
I mean, as long as it's an electric prop. Don't wanna use a gas or nitro prop. Most cheaper plastic props are fine. And yeah, I'd go with any 1045 prop. You probably Wana stick with ccw tho as any plane with thrust angle built into it will most likely require ccw props to work correctly. I don't think any of FT designs have thrust angle except for the minis.
Long story short, yes. Any prop thats a 10x4 to 10x4.5 should work fine.
