JTarmstr
Ok so with the destructive element in my mind, I have an idea. Anyone who has worked with army helicopters or is an military aviation nut like me knows that Helicopters such as the AH-64, AH-1, MH-60, MH-53 and a lot of life flight helicopters have wire cutters on the front fuse and tail, that way when flying at low level they can cut wires they run into before it hits the rotor shafts and potentially causes more damage.
So what does this have to do with BOB? Well I propose a sort of 'Plane Cutter" A carbon fibre or fiberglass stick mounted with epoxy to a small baseplate made of aircraft grade plywood at about a 45 degree angle forwards, From what I have seen of the videos of BOB, he gets hit enough to make it a possibility that 1 or 2 of these would possibly destroy someone's prop or wing in combat.
PS: if you want it to look cooler use a bit of dollar tree foam to make it look like a real wire cutter.
