Hello everybody, if you are like me, you go to the flying field, fly, charge up batteries, and fly again. But the problem is my flights are generally about 4 minutes max, so to help fill in the time, I designed a plane that could ideally fly for a while, preferably until the next battery is charged. I designed the plane to carry a lot of weight, and to be really efficient. With school finally over I can start putting in more effort and time into my projects, so if you want me to post updates as I build, I could do that, or I could wait until the maiden, just let me know whats best. Of course from the pictures, you can see all the imperfections which i didnt bother fixing due to me being unsure if the plane would fly, but i plan to fix it. Enough talking tho, so heres the design.
here is a video, but try to ignore my dads terrible video skills:
the wingtips are angled 10 degrees upwards to help stabilize it, but I dont think its needed. In terms of flight time (its main purpose), I got 5 minutes from a 4s 3000mah, and after landing and checking the battery, to my suprise, I found it was at 70% still. I could probably get 15 minutes with one battery, and 30 minutes with two, but personally, 15 is enough for me. It uses the motor from the ft power pack F, and 5 servos. I'm working on landing gear for easier launching. It is 41" wingspan, and 46" long. If enough people are interested, I will get some pfd plans for yall to make your own.
In terms of flight characteristics, it's very easy to fly, with no flaps or airbrake (which could probably be added if wanted). Its not meant to be an aerobatic plane, but it certainly is capable of some. I think it would also make a nice fpv plane, as there is no prop obstructing the view. I think it would also be able to be converted to a vtol failry easily, but I have enough projects as of now. That is for a future idea. I also had an idea to put a (*spicy*) edf on it, but I'm out of money. Thanks for reading, and leave any questions below.
