Didn't work today because of rain so I got some progress done. My pull pull deal is working
. The little white tubes I got from the kids water balloon kit, it hooks to the water hose and fills up about 20 balloons all at once and those tiny tubes I said I may need those somewhere done the line and worked out perfect. They are cut to about 60mm, just enough to guide the wire at each end in and out of the shaft. I had to stand the servo so for clearance for the servo arm a little heat and bent them down which gave me just enough room.
Now to see if my rx will fit in there , plus I need to see what I can use for a battery. May need to take one of my older 1300 3S battery and turn it into a 2S
