nikbrewer1
Well this is my 3rd version. My father in law had a mishap with his carbon cub due to the flight controller
It nose dived very hard. After looking at the body there was some decent damage, and with the front crushed so bad I could not figure if thrust angle was correct.
The fuselages are on back order so I decided to build a replacement from foam board.
Due to the safe+ and gps and the reverse throw servos everything had to mount up just like it was.
Well I did several attempts and adjusting small bits every time. This one will attempt to fly tomorrow.
I got all the electronics to mount correctly and even got a curve battery hatch and landing gear mounted.
Just need to build a cowl tomorrow. If it flys I will build another from FT brown foam and paint it.
