leaded50
This unusual bullet-shaped plane made some roars when suddenly was spotted.
The potencially revolusionary Celera 500L is said to be the biggest thing to happen to both the aviation and travel industries in 50 years , with its highly aerodynamic overall laminar flow shape, which produces approximately 59 percent less drag than existing similar-sized, more conventionally-shaped aircraft.
Its a mid wing, rear pusher configure plane.
Some time ago, some discussion was on this plane at web, and wondering on someone made a model. Here too, its not so much info given on the plane as length, wingspan measures eg. only internal height/width, and what dieselengine eg. And, pictures isnt easiest to give correct measures.
Some time ago i made a Piper Jet plane, and its wing have some recemblance with the one at the Celera... some at least. and since that wing is detachable, i decided to use it , change in what plane i can use it on. ...then just need build the fuselage on the Celera.
Out of the pictures who is to be found, (none in 3D view) i decided fuselage needs be approx 850mm long + the endpart behind tailfins to fit the 1280mm wide Piper Jet wing, with a diameter of 185mm. Every part shaped as in "master style builds" , but here made in two parts -one top, one bottom, to make easier the skins, and adjustments when needed.
