Cessna A152 Aerobat (MS)
Jonny Gum
Here is my drawing of the Aerobat wing so far. Should be ready to build when I have time.
I haven't yet decided if doubling the flaps and ailerons is worth it. By sanding one of the layers, the surface will match the triangular cross section of the wing, but its also a lot of work for an insignificant detail. If you look at the cross section in the bottom left of the attached image you should be able to see what I am referring to.
Tench745
It is a bit of extra work and, in my experience, makes little difference to the maneuverability of the aircraft. It does make for a stiffer control surface with slightly less drag that also looks better.
You can always try it without then add the second surface and see which you prefer.
Jonny Gum
I built the first version of the wing and have made minor adjustments on the cad design, including removal of the double layered control surfaces. Hopefully the version 2 wing will line up better.
Jonny Gum
any updates?
even if plans are rough and just enough I would be really happy to build this
It’s still on the back burner, I’m just super busy going into spring. Will keep updated as I want to at least finish before flitefest.
Been a while, I have a wing sitting in my room from this project but never got beyond that. Life is busy sadly and haven't been active in RC. I have ideas for projects but not sure if they will see reality.
Why don’t you just modify the ft commuter fuselage to work for your wing design?
