I maiden the 80% ( 21" wingspan, length 29" ) with 1804 motor, 3s 500mah, 5X4 prop. Total flying weight was 195grams. I was hoping mini power pod would fit but not quite so I glued it in. Seemed fast enough going straight but just not quite enough thrust, barely had some vertical and rolls weren't near as tight as I wanted. Will adjust to the outer most hole on servo and see if I can get more throw and will do a 6X3 prop and see it that gets me a little more thrust. If not will have to build at 70% and see if can get to perform with my existing 1804. I have a 2204 motor that would have no trouble with vertical but really want to try to make 1804 work.
I did manage to hit a tree on the second battery, luckily didn't get stuck just a crumpled nose and few bites out of the wing.
No decorations still just foam board until it flys well enough. Easy enough to build likely will wait until next one to add color.
Pictures with the 6X3 already installed. Just the right length slot for it.
