Hey guys I just upgraded to a 200watt 10amp charger from my old hobby king 50watt charger. My power supply keeps cutting out when I try to charge at 10amps. I'm guessing there isn't enough power. My old charger could charge at 4.5amps and that was the max. My new charger it will rise to about 3.5amps and then cut out. The charger is fine because I tested it on a car battery and it will charge at 10amps. The max power of the computer power supply is 330watts but it says 3.3v + 5v + 12v = 330watts. Then it says 3.3v + 5v = 200watts. I soldered all the 12v cables to the banana plug with the same number of ground wires. How can I overcome this or get the most power out of my computer power supply?
