could it be made without the droperons
Yes, absolutely. They are very much optional as a way of changing the plane's performance in a way that remains to be seen - I figured I wanted a good bit more aileron surface area than I was able to get with the flaps where they were and so chose to put it on the leading edge. If you'd like to make the plane a tad more beginner-friendly you can build them and then tape or glue them in their fully drooped position so they act as a leading edge cuff, which should delay stall of the wingtips by decreasing the effective angle of attack of the outer wing.could it be made without the droperons
You probably could, but there are two major factors that cause me to not recommend this: First, the elevator must be able to deflect downwards, which puts it right into the space where the motor or its supporting structure would be. You could split the elevator on either side of the fuselage to get around this, but I don't think you would have an optimal experience due to the next factor: Prop clearance. As it sits, it has ~6.5" of prop clearance. When at its maximum ground angle of attack, resulting in a tailstrike, that decreases by nearly five inches, leaving you with less than two inches of clearance. Using a single power pack C as pusher with this design would not allow the plane to perform its best by severely limiting the angle of attack on takeoff and landing.and do you think you could mount 1 c pack motor in the tail... instead of 2 f pack motors?
but keep the wing motor pods(without motors in them obviously)
What was your max angle for the drooperons?
I like this airplane. If you would like to collect and share performance data (i.e. speed/power curve at various weights, most efficient cruise speed, etc) for the Cormorant II I'd be willing to donate an FC and GPS to the cause.
Hi my friend, your efforts are appreciated and I hope you can fix it as soon as possible.The aftermath - note the half of the prop blade sticking out of the fuselage! Surprisingly, the nose was barely damaged. It looks repairable, and it's very much in the spirit of this paint scheme to be imperfect and scuffed. I'll see what I can to to get it back in the air.
Your efforts and perseverance are appreciated .View attachment 187626 View attachment 187627
And just like that, it's back and ready for action
Thank you!Your efforts and perseverance are appreciated .
The description was excellent and the pictures were very clear.Thank you!
I know y'all have probably seen enough of this plane already but I think this is one of the best pictures of it I've got so far:
The skis work great on proper snow. They've been added to the plans, along with some changes to the battery tray and minor fixes.
Here's some guidance on building the skis:
Start with the Main and Nose Skis. Bend up the radiused nose (you can use the 20* angle gauge for the wingtips here too) and glue them in place. Next, cover the bottom of the skis in packing tape, making sure to bring the tape over the edge and onto the top of the ski to prevent the paper from delaminating. Then take both the main and nose plates and peel the paper off the side with the score cuts. Open up those score cuts with skewers, and cut the skewers such that there is around 3/8" of length on either side of the plate. Glue the skewers into the score cuts, glue the plate with cut side down onto the skis, center them in the rectangular section. Once they have dried, peel the paper off the top of the plates. Next, take the two main chocks. Crease them in the middle to a 90* angle and bevel the edges. Glue them between the two cutouts in each main gear plate. These will sit between the wheels and serve to keep the ski from moving fore and aft. Next, cutout the wheel guards and take the paper off both sides. Glue these onto the plates to the side of the wheel cutouts: there should be two on each side of each wheel to prevent the skis moving side to side.
To install the main skis, you'll need four rubber bands. Pass the bands under each wheel such that the two ends of the loop are on top of the wheel - this can be accomplished by bringing the loop over the wheel and rotating it such that it brings the other end of the loop around the other side. Repeat this for all four main wheels, then attach them by looping the bands around the skewers. This process can be repeated for the nose gear, although you may have to use a smaller band (or twist it back on itself to form two loops). Attach a piece of scotch tape to the nose of the nose ski and tape it securely to the underside of the nose. Make sure there is sufficient slack in this such that it will not pull itself off if the nose gear is fully compressed but not loose enough to where the ski refuses to stay facing straight ahead.
View attachment 187843 View attachment 187845 View attachment 187844 View attachment 187846
