Coptercentre UK
Hi!
Let me introduce you my new designed gimbal for small action cameras , e.g for mobius.
The main goals during the design of the brand new CS-1 were to create a gimbal that is lighter than any existing one to extend flight time, yet remains rigid and retains the flexibility of mounting options as well as the compatibility with the most popular multicopter brands (and gimbal controllers) and a variety of cameras, too. In order to achieve these targets, unique, ultra-light frame, mini gimbal controller and special 18 g micro motors have been built and tested in various different setups.
The gimbal has been designed for Mobius cameras but any similar size action cams can be mounted on it, such as Innovv, Topcam or the 808 keychain camera
You can follow the official information about stock on the product pages in our store: http://stores.ebay.co.uk/coptercentreuk/
Our webstore: http://coptercentre.co.uk/
Support thread on RC Groups:
http://www.rcgroups.com/forums/showthread.php?t=2325358
RTF:http://www.ebay.co.uk/itm/Ultra-lig...K-stock-/291348069133?ssPageName=STRK:MESE:ITARF: http://www.ebay.co.uk/itm/Ultra-lig...K-stock-/291353825347?ssPageName=STRK:MESE:IT
MANUAL (read me!): http://www.ebay.co.uk/gds/Coptercen...us-ActionCam-manual-/10000000204650447/g.html
TEST VIDEOS:
upside motion: https://www.youtube.com/watch?v=xHVT7br7Ea4&feature=em-upload_owner#action=share
test with a gopro:
http://youtu.be/aZyyzd01Zec
in flight frame and motors:
1. http://youtu.be/DnSYyXYYK68
2. http://youtu.be/0Wn7pcvERhI
ultralight, RTF weighs only 98g-100g based on wirings and controller type(without camera)
-can be used up side down operations (180 degree mounting)
-strong CNC aluminum frame
-adjustable frame arms
-adjustable mounting plate with variable sensor mounting platforms
-RC pitch (camera tilt) and roll control
-BGC 3.5 mini alexmos controller (with 2.4b7 Fimrware)
-simple setup using SimpleBGC GUI software
-pre-calibrated plug&play configuration for different camera setups (e.g mobius with or without mounting bracket, lens normal A or B wide)
-multi compatibility for mounting your own mini or normal size (50x50mm) gimbal controllers
Frame spec: 43g
Weight: 95g (including all electronics, excluding camera)
Ground clearance with mounting screw : 85mm
Ground clearance without using mounting screw (with mobius stock mounting bracket): 80mm
Motor spec GBM-1806:
Poles: 12N14P
KV(RPM/V): 80
Resistance: 18omh
Weight: 18g
Wire: 0.17mm
Bottom holes center to center: 12mm and 16mm
Top holes center to center: 9mm
Mounting screw size: M2
Controller spec:
8-bit version of the SimpleBGC gimbal controller
- 2-axis BGC V3.5
- Built-in sensor and USB port
- DVR8313 motor driver
- 2.5-A peak or 1.75-A rms output current per channel
- Driving current: 1.75A max
- power connector: balance plug (for direct connect of 3s lipo battery)
TEST VIDEOS:
test with a gopro:
Frame spec: 43g
Poles: 12N14P
KV(RPM/V): 80
Resistance: 18omh
Weight: 18g
Wire: 0.17mm
Controller spec:
- 2-axis BGC V3.5
