Air Assist is definitely on my To-Do list. 5 Passes isn't a horrible number. I don't know squat about laser theory. So if you can do 1/8" in 5 passes with a 3W laser, shouldn't you be able to reduce the number of passes by (aprox) 50% if you increase the power by 50%?
That was already at the max power of my laser. At least as high as I'm willing to go with it (you can push them higher but you significantly shorten their life.) Cutting a motor mount for my FT Explorer took almost an hour doing 5 passes (I forgot to mention that the feed rate had to be VERY slow as well.)
After reading your post, I checked the specs on the JTech 3.8 and 7w laser kits. Spot Size = 0.011 on both. 6mm spot size? Death Laser?
I don't see myself needing a CO2 laser anytime soon.
Jtech has good stuff...but man are they pricey. That 7w laser is more than twice what I paid for my 40w CO2 machine...and that's a full machine not just a laser. Yeah, I had to do quite a bit of upgrades to the machine and I stepped up with a smoothie board - but if you're really just interested in cutting then you could go with a RAMPS for over $100 less and have an equally useful machine.
I also note that jtech doesn't list a max spot size and show a typical spot size larger than the quoted smallest...so...not sure just how accurate that info is. Note also that by their nature diode lasers tend to have an elliptical spot rather than a round spot which again results in slightly less efficient power delivery to the work.
They do note that the spot is rectangular and the size quoted is the longer dimension. They also note that actually running it at 7w output will significantly shorten it's life. So selling it was a 7w module is to me a bit misleading.
Also, from what I've read on Banggood https://www.banggood.com/EleksMaker...-p-1127310.html?rmmds=search&cur_warehouse=CN and elsewhere, 7W laser can even mark stainless and aluminum. That would be plenty enough for me. But I'm very nervous about Banggood at $300 and choking on JTech at $625.
I've actually had success "marking" aluminum with my 3w. Even a 40w (or 60w) CO2 can't actually "mark" aluminum though - what's actually happening is you can etch the anodizing. If you have clear anodizing then it looks like marking but the aluminum itself isn't actually being marked. And the quality of the anodizing can vary wildly. Surprisingly the anodizing on my cheap HobbyKing Charger is REALLY tough stuff as despite being black I can barely etch it at all even at high power and low speeds with my 3w...but most other anodized things I've tried have etched very easily at higher speeds and lower powers.
The big price difference between jtech and the Chinese sellers is in the support Jtech provides and the provisions on their drivers to meet US safety regulations (keylocks and dual interlocks). Most of the actual laser diodes in the modules that jtech sells you can get direct at much lower cost - but you have to source your own parts to assemble it into a working solution. My laser used the same diode that was in jtech's kits at the time but I spent about half what they were charging to put mine together. I had to order parts from multiple sources to pull that off...but the cost savings was worth it to me and the safety locks weren't as important to me since my machine is in a locked building that only I have access to. If it was in my house where my daughter could get to it (like the CO2 laser is) safety interlocks would be far more important (and that's why I added them to my CO2 laser!)
I love my diode laser - don't get me wrong. It's VERY useful and I'm glad I have it. But I'm also glad I didn't spend much over $100 putting it together and am even more glad that I now have a CO2 laser as well for real cutting. Even so I'll be keeping my 3w laser because it has a MUCH larger working area even if it isn't nearly as powerful.
