Springer
I have a question for the gurus! I have been using the 2.5watt laser on my CNC machine (had to temporarily remove the needler) to burn sayings into some wood disks for the wife. I had done this on a trial basis a few months ago and didn't see any issues other than sorting out the speed and power mix. Now running the actual files, I noticed that the insides of letters (like the center of an o or b) are displaced in the x axis. It doesn't seem to affect the Y or Z axis, but it occurs after moving from one completed loop to the next one, at the time when the laser turns back on. I thought it was always shifting left, but today, saw it sometimes shifts right. The first loop is burnt correctly, and the second appears to be correct in each case, but just shifted left. I took some video today (the vimeo file), and while it is somewhat hard to see, it does show the smooth motion in each loop, and the jerk at the start of the next one. I checked the code and there is no spurious step in it, the visualization is smooth. I thought that maybe i needed more power, so switched from the 2.5amp max power supply that came with the original laser cutter i made the machine from to an AT powersupply based unit. No change. I also thought that maybe the laser wiring was too close to the stepper wiring, sending a pulse, and separated them from the spiral wrapping, also no change. Am I dealing with a bad stepper? the fact that it tracks perfectly in each loop seems to belie that. What d'yall think?
The picture shows how the letter centers are displaced.
