Last night I was working on other things in the garage, but kept thinking about the cutter. Even with the mig tip, I still get side to side deflection. The guides you guys have developed fix the problem, but are getting complicated. This is what I am trying now:
Using the 3/4" block with a small hole at the top with the edge of the hole eased. The hole for the mig tip threaded into the bottom is only as deep as the threads. My needle is not deflecting anymore.
The tip was fairly warm after the first test, so I added some fins. They are shockingly effective. Just drill a 1/4" hole in thin aluminium, but as soon as the bit breaks through, stop and leave the bur.
Interesting... I was thinking similarly. Instead of sideboards or bearings, just a simple block with small, eased hole to "preguide" the needle down to the needle guide (not shown) below...
PS: I think I like your all-in-one [block] idea better however...
-- David
I was thinking like you were first. How can I sandwich a block above and below? Then I would also need to make the printed part taller. Then the single block idea hit me. It is working great so far. My kerf is the smallest I have ever achieved.
I like it. You could progressively elongate the holes in the upper layers to reduce the bending force at the entrance of the block. It should work great. I was also pondering this morning whether we need a metal guide at all if the wood is thick enough and the hole is tight enough. It would be interesting to see how long it would last.Rather than a drill-press exercise with 3/4" material... or rasslin' with trying to cut 5mm plywood with a 2.8 watt laser... I decided to take the easy way out and cut multiple copies -- in just one pass -- of the pattern for a preguide and/or upper/lower guide out of craft sticks. I figured that laminating them and using the mounting bolts for registration would allow for sufficient alignment... at least as good as I could accomplish using another approach. Just a fit/alignment check...
I think I can make this work...
-- David
I have submitted an article on my machine. I think you can see the preview at this link.
https://www.flitetest.com/articles/build-your-own-cnc-foam-cutter?preview=1
I welcome comments from you guys. I can still make edits while it is waiting for review.
Thanks,
Mark
This is an awesome idea! How clean are the edges of your parts when they are popped out of the sheet though? I'm just wondering if for the style of airplane building we are all using if this method is better than what FT is using. The reason I say this is because when you cut foam board with a laser, sure, you get a nice clean edge on the paper, but the foam in the middle seems to tend to melt back a little bit which also encourages the paper to start peeling sooner since there is a little bit of a loose edge to the paper.
Looks nice Moebeast! I actually submitted one earlier this week as well and have been waiting on approval...didn't know you can share the preview links like that: https://www.flitetest.com/articles/cutting-foam-sheets-with-a-needle?preview=1
I tried to focus more on the needle cutter itself rather than the CNC...but I like your approach too! We'll see what the Monkey picks to approve - I say they both should go up
I thought you might have beat me to it, but with all the work you've been doing on the Low Rider, I figured you may have put it off.
I tried to give an introduction to the topic with links to more information. It would take a book to cover everything. I like your detailed explanation of the cutter. We could follow with a detailed article on creating files.
David, I'm glad to share, and I'm glad you like it. We got some publicity on the Angle of Attack podcast last week. I had to show my machine to Crash Hancock since he inspired me to get into CNC in the first place. He was impressed with the needle cutter.
I've given some thought to doing a MPCNC-style (printed parts,conduit,etc), Phlatprinter-inspired, dedicated foam-cutter CNC machine. Like the PhlatprinterIII (and the typical Cartesian 3d-printer or HP plotter), the material moves... the sheet of foam is driven back and forth by a roller mechanism and the needle cutter moves above it in the orthogonal axis. It would be a smaller-footprint machine, needing only sufficient room in front and back to allow the foam to reach the extremes of Y-axis travel... and might be useful in smaller spaces. -- David
