I use ESTLCAM and only use engraving because inside/outside only work on closed polygons (unless that's changed in 10 and I haven't noticed since I haven't tried using them on open cuts yet.) Engraving is a centerline cut and allows for non closed shapes so I can do things like hinges and other cuts that don't form a polygon.
My process setting up the CAM is outlined here:
That skips the first 7 minutes or so of the video which is prepping the PDF in inkscape to convert it to DXF/PNG for CAM.
That was an older video though with ESTLCAM 9 and my older cutter. With the new cutter I've revised my tool settings quite a bit as can be seen in this video (again skipping the first 15 minutes which are inkscape)
I used to set the toolsize to 0.9 since it didn't really matter as I only do engraving/centerline cuts. But with the new upgraded tool I've set it to 0.62 - the actual size of my needle - since it makes the views a little nicer (smaller path around the cuts.) I have used inside/outside (part/hole) cuts but usually don't bother since I can just stick with the engraving tool and not have to switch tools. Though I do sometimes switch from automatic to manual depending on the way the file is drawn and how well estlcam detects the lines.
I also save my files to SD and run from there. My controller is a bit far from my computer to stay tethered and I don't trust windows not to crash or screw up timing during a cut anyway.
I'm still not sure what moebeast and I are doing differently...but I have zero need for tabs, my parts are fully cut and I get clean edges...but they have to be popped out of the foam. I think he may be running a thicker needle than me but I'm not sure.
I've been trying to collect some photos/video to do a video on the benefits of the needle cutter. With all the talk about the Rascal on FB and people asking how they plan on cutting foam I want to help spread the gospel of the needle over the spindle
I like my spindles...but not for foam.
Reasons?
First a word about spindle options:
My spindles are all routers, I don't have an actual spindle. But a DW660 is only $50 on Amazon so it's a very affordable spindle option while a DWP611 is about $130. The 660 is also smaller and lighter. The 660 is 5amps so about 500w on 110v. The 611 is rated as 1.2hp so about 900 watts. So you do get more power from the 611. But...the 660 includes both 1/4" and 1/8" collets and you'll usually be using 1/8" bits on these machines. The 611 only includes a 1/4" collet and a 1/8" collet is about $30. So that bumps the price of the 611 over $150 to actually be usable. The MPCNC also doesn't have many mount options for a 611 though they are popular on shapeokos and other desktop CNC's. Oh, the 611 is also variable speed which the 660 is sadly lacking - you can use an external speed controller on a 660...but...it probably will shorten the tools life since it also slows the cooling fan.
I don't know exactly which spindle they're running on the rascal (I'd really love to see some of the guys working on it chime in here - Nerdnic, Sponz - you out there?), but it looks like the "standard" cheap Chinese 500w spindle. Those run about $130-$150 (Though banggood has one for just $80) The reviews I've heard about those have not been super encouraging. They do tend to be quieter than the routers from what I hear...but the power supplies/controllers are questionable and the spindles tend to have more runout than either dewalt option. They're lower RPM...but honestly the 660 is higher RPM than needed (and that lower RPM is probably a big part of the sound difference. The 660 does ~30k RPM while the Chinese spindles only do about 12-15k) I've been tempted to pick one up a few times...but they just seem to be a fairly big gamble...I've seen lots of people happy with them. But I've also seen a lot of people go back to a router because of the issues they experience with the cheap spindles. They also look like they're probably lighter...but I can't find any reliable numbers to confirm.
1) Sound. My needle cutter cutting is 5db quieter than any of my current spindle options free-running. The chinese spindle as I state above is almost certainly quieter than my spindles...but I doubt it's much quieter when actually cutting. I can't really demonstrate this point with photos
2) Mess. Cutting foam with a spindle makes a mess. That foam dust is really obnoxious. It gets static charged and sticks to everything. I really don't like having it in my shop, I worry about breathing it and it gets on everything even if I follow the bit with a strong vacuum while it's cutting. I've been meaning to get some photos/video showing this...but I really don't want to make the mess it requires
Here's the mess the needle cutter makes:
It's hard to see...but you can see some small dust on the board there. Honestly...most of it is dust that was on the foamboard before I started cutting it (mostly dust created in my shop from cutting MDF with my spindle) and the needle just makes it more obvious since it bounces around while the foam is being cut
I occasionally get a bigger "dust bunny" like this from my cotton ball oiler shedding a bit. This thing is still tiny. And a quick puff of air blows it away.
The tip of my needle cutter does collect some fine dust while cutting. A quick wipe every now and then easily keeps it under control.
But overall the needle cutter just doesn't generate much mess, It mostly pushes the foam and fibers of the paper aside. And the majority of what it does displace gets pushed down into the spoil board.
3) Accuracy/Precision - Honestly neither is quite the right term. It's more the VERY fine kerf that I'm trying to express. It is accurate and precise ( I get cuts the size I expect repeatedly ) but what I really love is how that fine kerf allows for very clean cuts that beat even a laser for DTFB and in some ways even beat most handheld knifes. Photos show this best:
Note - these photos are extreme closeups the edges may look a little rough on some of them (my needle could stand to be sharpened and I have been running my feeds a little higher than what gives optimal quality) but that's mostly due to the extreme closeness of the photos. Even "clean" exacto blade cuts don't look perfect this close up.
A spindle even with a 1/32" bit isn't going to do that. 1/32" is ~.8mm which is about .2mm thicker than my needle. Now, my needle does have a tiny bit of play in it...but that Chinese spindle is going to have some runout as well so we'll call that even. That V on the left would be an "outside" cut with a spindle - so the CAM software won't go all the way into the vertex of the V since it has to account for the size of the tool. (1/32" bits aren't cheap either and are easy to break...but that's part of my next point)
Here's that same cut completed. It's hard to tell but the deepest part of the V was actually cut twice. Once going in and once coming out (remember I use engraving/centerline cuts) Basically where the V goes in up to where it meets the score line on the left that line was cut twice.
Speaking of accuracy. I've got my Z dialed in now where I can do marking cuts that don't even pierce the top-paper. They just lightly dent it
You could come close with a rotating bit...but you're not going to dent the paper without cutting it.
This ultra fine kerf also simplifies workholding. I could use a vacuum bed - but really don't need one. By placing the foam so the corners curve up and then pinning the corners it lies flat enough I can get more than enough accuracy for RC planes. And with the fine kerf parts don't "fall out" so there's no need to hold parts in place after they're cut. I still want to build a vac bed for the really warped sheets of foam...but I try to avoid using those for planes anyway. I mostly want a vac bed to go with my spindle for cutting wood where work holding is considerably more difficult.
4) Cost - The cheapest spindle option is a $50 DW660. The cheapest "real" spindle is about $80. Better spindle options like the 611 and nicer Chinese spindles you're looking at $150-$200. And then there's bits. A decent endmill runs about $4, you can get cheaper ones from banggood/aliexpress but they're not a lot cheaper and they're generally not nearly as nice. drillman1 on ebay has the best deals I've found on quality endmills. I got some cheaper endmills off banggood and they don't cut as clean, don't hold an edge as well, and overall just weren't a deal despite their low cost. These small endmills are also remarkably easy to break. Now to be fair we're cutting foam - so an accidental move has to be pretty big to break one ( like down into the worktable big.) But when you're dealing with 1/16" and 1/32" bits...they're crazy delicate. I broke one by dropping it - $4 of kyocera goodness down the drain and never even got to try it
The point is - the tooling is expendable - and while you can resharpen a knife blade (or a needle) resharpening an endmill is not something most people will tackle in a homeshop.
The needle cutter on the other hand...is made from stuff that most RC hobbyists probably already have on hand. If not a $8 motor and $8 ESC are all you really need. The 3D printed frames are nice but not 100% necessary - David built one of his from a dollar store mousetrap - and you get more than one mousetrap in that package for $1! The bearing guides I'm using are nice...but a few strips of wood work as well and are probably even quieter. The MIG tips are great, and you can get 10 for $5 at harbor freight - that's more than a lifetime supply for this use - so share with a friend and save even more
Or just get a $2 pack of sports inflation needles - they don't last as long but they're cheap. Bottom line, you could spend more than $50 building a needle cutter...but you'd probably have to try pretty hard to do it.
Yes, needles are an expendable item just like rotary bits. But...they're easy to sharpen, and enough wire to make about a dozen needles is <$4 at just about any hobby shop. So for the price of one endmill you can have a close to lifetime supply of needles. And if you've built many RC planes you probably have suitable material on hand already cut from the ends of your control rods (though the 0.62mm stuff I use is a bit less common unless you're into DLG's or something like that! The slightly thicker wire will work but you'll get a slightly wider kerf and possibly less life out of the needle.)
Being able to mount a spindle on your CNC rocks. They're great for cutting wood, plastics, CF, and some soft metals (and if you're REALLY patient and have a stiff enough machine even some harder metals.) But if you're looking to cut foam...IMHO it's just the wrong tool for the job.
I love my spindle. Later this weekend I'm probably going to be cutting some MDF plates for a friend who's building a C-beam based CNC machine. But I love my needle cutter more - it's so much more enjoyable to use and so much easier to learn with. Foam is cheaper and more forgiving than wood in so many ways.
