Grifflyer
WWII fanatic
Introducing the Grunjet, a two sheet foamboard performance jet flying fast and sporty, slows down to a crawl on landings, and is packed with amazing vertical performance, all only costing $80 to build! With this plane you have the option of building the plane with a V tail or a standard tail, there are no real handling differences between the two other than the fact that the V atil has a rudder.
-Videos
-Overview
-Speed
While certainly not a speed demon, coming out of a dive it might get up to roughly 70mph.
-Handling
With such a low wing loading this thing flies like a trainer, and with such large control surfaces you're able to pull of a ton of aerobatic maneuvers.
-Stalls
They can become little rough but I have yet to drop a wing
-Aerobatics
If you build the plane with a standard tail you'll only be able to do the basic such as: loops, rolls, inverted, split S's etc. Even if you decide to build the V tail there's quite a bit of adverse roll when you apply rudder (a common characteristic of V tails) so you'll still be relatively limited to the basics
-Take offs
You can either do an underhand launch while holding the thrust tube, or my favorite, just plop it on the grass and give it full throttle and off she goes!
-Landings
With such a large wing and low wing loading you can glide it in without any problem, but I prefer to leave a little bit of throttle on to get some airflow over the elevator so I can flare it right before hitting the ground.
-Skill level
This is the easiest jet I've ever flown, if you want to dip your feet into the sweet waters of EDF jets this with by far the best way to do that. This would make a great second or third bank and yank airplane.
-Plans
Grunjet Plans V2.0
-Videos
-Overview
-Speed
-Handling
-Stalls
-Aerobatics
-Take offs
-Landings
-Skill level
-Plans
Grunjet Plans V2.0
