DIY helmet rig for combo visual and FPV flying
I made a convenient and cheap holder for a monitor or helmet and decided to share this wonderful invention with the community ... made of 5mm polycarbonate, two belts and three screws with wing nuts ... bent plastic heating it - you can take a PVC pipe or plywood and a couple of corners if there is no carbonate ... it happened so conveniently that made two versions of the helmet from the first video simply folds and secondly the addition of shore with the helmet removed, and is formed into a plane remains a single monitor with a u-shaped bracket 300mm*200mm*30mm (battery compartment mounted under the monitor ) this design allows even to run for UAV ,hands free and excellent visibility to both FPV and visual , is attached to the body very easily and quickly two straps (cross in back)
