Scooter The White Rabbit
I've sat here waiting to buy equipment for my two Standard size DTFB planes with an idea in my head. I want to seriously build a usable Search and Rescue aircraft with the following capabilities.
1. Large Cargo Aircraft/Heavy Lifter.
a. Large Usable Cargo Bay.
b. Controllable Multiple Cargo Pod/Palate Drop System. (Servo operated one-at-a-time drop system).
c. 6.6 lbs./3 kg. Cargo Weight Above Plane W/Full Equipment Load-Batteries.
2. Long Range Capable.
a. Time in Flight. (Push Flight Envelope to 30+ minutes).
b. Distance Controllable. (Flight/Video in Miles/Km Distance)
c. Easy Battery Access for exchange for continued flight missions.
3. Easily Built/Repairable Airframe.
a. Sectioned for ease of transport. (Two Part Wings/Nose-Cockpit/Tail-Rudder-Elevator/Main Fuselage)
b. Light Weight and Strong.
c. Built in Survive-ability and Serviceability. (Rough Weather Capable.)
d. Strong Large Wheel Landing Gear for Rough Terrain Take-Off/Landings. (Nose gear need not be servo controlled).
e. Aerodynamic Blended Wing Attachment. (L-lock leading edge, Twist-lock trailing edge.)
f. Separate Controlled Cargo Bay Door/s.
5. Video Systems.
a. FPV W/OSD, Switchable to 2 Auxiliary Cameras, Wide-Angle Down, Cargo Bay Check View. (External Cams Day/Night Vision)
b. Auxiliary Monitored Day/Night Vision/Thermal Down View Cameras.
c. Internal and external recording capabilities of all cameras.
6. Lighting Systems.
a. Standard Navigation Lights W/Strobes.
b. Landing Lights Switchable to Off. (Must be bright enough to assist FPV VFR/OSD Instrument Landings)
c. Internal Cargo Lights for Drop Control/Verify Drop.
(d. Possible Belly Mount Search Lighting, including Ultraviolet Night Vision assist.)
7. Power Hub power control system.
a. Output for 4 motor system.
b. Output for servo system.
c. Output/s for camera operation.
d. Output/s for Lighting System.
e. Master Battery Off/Safety Switch, W/Flagged Insert Key. (Large Red Reflective Strip for Quick Visual Reference).
(Listing of Aircraft Requirements will be adjusted as needed/suggested)
The C-130 J-30 is chosen at this time due to it's service record of foul weather flight capabilities, and cargo capacity. This SAR aircraft will be flying under 400 ft./ 121.92 meters altitudes, more than likely tree top level per local area typography and vegetation. To fully assist in SAR missions the aircraft will be flown out of Line Of Sight. Thus such items as Down Aircraft Beacon/Alarm will be installed. Although Flight Crews will coordinate with Ground Search Teams to increase Line Of Sight Command Location and Search Team Awareness of the craft and it's flight path/pattern.
Flight Crews should consist of a 3 person team, Pilot, Spotter/Navigator, Search Monitor. They should know the aircraft and all of it's systems inside and out. Previous Air Crew Operations knowledge and training a plus. The Ground Station must be portable, and protected via tent or trailer unit during foul weather/night operations. The Flight Crew must be in constant communication with SAR Command, and be able to relay Air SAR Operation capabilities for mutual understanding of level of assistance system can bring to the op.
The main reasons for such a system build are as follows. A Long Range Extended Flight Time Fixed Wing Remote (UAV) in this configuration brings more eyes in multiple types of view (Day and Night Vision plus Thermal), and multiple cameras on one platform. OSD (On Screen Display) systems add GPS coordinates for plotting location of lost/injured persons, assisting ground crews in plotting safe and timely access routes to victims with recorded over-flight video replay, or live-view. In addition, these aircraft will have the capability to drop Emergency Supply Packages to lost/injured victims at time of discovery, or afterwards if conditions change. These ESP's can include many things such as location beacons, space blankets, water and energy food rations and first aid kits. Multiple ESP Drop Units provide for multiple person aid at one site, or multiple sites should a group have split up, or multiple individuals or groups be involved. ESP's can also be customized on the fly to assist Ground Search Units in extending their search abilities without need to return to base. Batteries, food, water, equipment for repelling/climbing, splint kits, hasty compact stretcher packs, micro-tents, can all be loaded and delivered quickly.
To answer one question this subject brings up. FLIR is located nearby in Wilsonville Oregon. I will be in contact with them concerning Night Vision and Thermal Imaging equipment. A local group know as "Roswell Flight Crew Team" operates FLIR Vue Pro cameras on quad-copters for the Portland Metro Fire Department. This is a local non-profit organization I will be also getting in touch with.
Any assistance will be greatly appreciated and notated during this build. I have given myself six months to have a base aircraft built for maiden flight testing. Of any organization I can think of "Flite Test Family" in my mind is the best resource for such an undertaking.
Ahead of time, I thank all of you.
5. Video Systems.
