After calibrating the ESCs(whcih worked this time), the motors seem to work well as far as I can tell. The motors correspond to the correct number when testing them on the motor tab, but I am unfamiliar with how they should act exactly when I input controls, I'll simply have to be very careful on the first flight and see what will happen.
Do you have any other things you know I should/need to configure for it before the first flight? I heard something about pitch angle which I needed to change on the tricopter for it to have any balance, but I am unsure.
Now the only problem that stands is that the servo is not responding. This makes sense so far though, because I have connected the servo data lead to the LED pin instead, because I read somewhere that the Kakute F4 V2 neeeded you to do this, since M4 did no support the servo protocoll or something along those lines. So now anyways, I need to configure the servo to use the LED pin. However, there is no SERVO resource in the resource list. Anything I am missing?
