Christopher14
Driftin' with the wind...
Christopher, If your radio is programmable than you can add differential in the mixing and save yourself the trouble of cutting a new tail. You just need less upward travel on your ailerons.
Do you mean less downward movement? When I roll the plane to the left the right aileron makes more drag then the left then causing the plane to do a knife edge like turn. The exact same thing happens when I roll to the right as well. And yes, I do have a programable radio. A Turnigy 9X to be exact.
