Sammy
Hi,
I've been trying to figure out how to setup mixing on my Spektrum DX7s for the flaps on the HK Bixler 2, but I can't get it to work. Here's my setup:
I can't use a Y harness on the flaps, cause one of the servos' has to be reversed. Currently the L-FLAP works fine, but the R-FLAP moves along with the R-AIL, which is obviously not a good thing![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I've been going through the DX7s manual a dozen times already, but it's not really helpful. All it tells me is to set up mixing, AUX1 should be set as master and GEAR as slave if I got it right, but this is exactly where I get stuck: when I select AUX1 as master, GEAR is not a possible slave and vice versa. Obviously I'm doing something wrong, but I can't figure out what? I have googled this and found a nice step-by-step guide for the DX7 (http://www.rcuniverse.com/forum/rc-...-dx7-flap-programming-4-servo-wing-print.html), but its menu structure seems to be different from the DX7s: I don't have Input Select, Switch Select is the one that comes closest I guess, but I can't change anything there, I only have Inhibit as an option...
Help guys, I'm going insane!
- Spektrum DX7s TX
- OrangeRX R615 RX
- Left Aileron & Right Aileron via Y-harness on AIL channel
- Right Flap on GEAR
- Left Flap on AUX1
