Greetings
nightm0de,
IcedStorm777 from another Coloradan! I am up north flying out of Arvada Aeromodelers (
https://www.arvadamodelers.com/weather/).
Picking up on Quorneng's post...
As other have said the important thing is to recognise that flying at altitude is aerodynamically a bit more difficult.
So what might just work at sea level will struggle the higher you go but a plane capable of 'unlimited vertical' will probably manage fine.
Although, unlike IC, an electric motor is unaffected by altitude (it will produce the same power at the same revs) but the prop it is driving is. To produce the same performance it will have to spin faster, have more pitch, diameter or a combination of all three!
Remember brush less motors are constant speed devices and produce a specific power at a specific rpm. Thus with the same prop the power produced at sea level will be greater than an altitude.
Put another way, as Hai-Lee suggests, when at altitude you will have to fit a bigger prop to get the motor to draw the same current as at sea level but make sure you use a Watt meter to check you are not over doing it!
Going back to your original question an EDF is much less efficient (about 50%) at converting Watts into thrust than a prop so when flying gets a bit more 'difficult' guess which is the better choice.!
I discovered a formula referred to as the propeller loading factor.
PLF = (diameter^3)*pitch*(number of blades-1)^0.5
It is useful if you want to convert between 2 and 3 blade propellers where you want the same performance.
I decided to use it as a rubric for how much I could out of different props. In my experience with a UMX Timber and a Turbo Timber, I've found that a 40% increase in PLF works well.
BUT, as was said above, you must use a watt meter to see what the current draw really is.
I received all the bits, including the Power Pack C, for my Edge today. I am expecting to try 10x6 and 10x7 props which are 33% and 55% increases respectively from the 10x4.5 stock props.
(As an aside, I've talked to folks at my field flying the Viper and Avanti and they have had no complaints flying EDFs at altitude.)
