The ElectroHub Y6 Kit is designed with our FPV Rail System which offers endless options for mounting camera and gimbal systems for AP (Aerial Photography) and FPV.
Click Here for a full list of everything included with the Y6 kit.
Below is the basic list of the accessories mentioned in this build, some of which are included and other items can be purchased separately!
ElectroHub Y6 Kit
- ElectroHub* power distribution hub
- Wooden Booms*
- Simple Y6/X8 Motor Mounts*
- G-10 Angle Arm Brackets
- Flight Control Board Mounting Plate
- FPV (Long) Rail System*
- Power Pack "D" (Hexacopter)
The Y6 copter is built around the ElectroHub power distribution hub.
The power distribution solder pads of the ElectroHub offer a clean and easy setup of your electronics.
You can build a really clean setup on your multi-rotor with the dual plates of the ElectroHub.
The Y6 is setup with our (Long) Rail System. You can learn more about this and other components in our store. The rails are made from lightweight aluminum.
The adjustable (Long) Rail System allows you to adjust CG and create custom camera mounting setups.
This landing gear is only available with the ElectroHub Y6 Kit.
The landing gear is designed to be customizable in height and length of the stance.
In this build, Eric set up his landing gear with a 6.25" height with a 7.5" length on the feet.
The ElectroHub Y6 Kit was created to offer a solid platform for flying Aerial Photography and with the ElectroHub and (Long) Rail System allow you to have a completely customizable copter.
The ElectroHub Y6 is basically a beefed up Tricopter with redundant motors.
When you are ready to mount your flight control board it's worth checking out our custom Mounting Plate.
The Flight Control Board Mounting Plate is an additional accessory but offer you a way to perfectly align your control board while allowing you to run your wires and create a very clean setup.
The G-10 Angle Arm Brackets are another optional component that is available in our Store!
You can learn more about how the Angle Arm Brackets work and see them in action in our Tough Tilt Episode.
The G-10 Angle Arm Brackets are available in our store along with the other additional components mentioned in this build!
The ElectroHub Y6 Kit was created to be versatile, customizable and cost effective.
We can't wait to see your custom AP setups with your Y6 kit!
