Clintonious
I’ve posted a few other threads already (like this one), but this one is going to be where I document the build process, what I’ve learned along the way and what problems I’ve run into. I’m also learning that there are a lot more resources available, but they’re somewhat scattered. I might try to document that too…
So I started building yesterday. I’m building a mighty mini trainer from a speed build kit.
(Guess what, it comes with all the parts you need except the receiver and battery! I previously wondered if I needed to buy the servo wires, control horns, etc. Those were all included.)
First thing I noticed… the laser melts the foam back a lot more than I expected! Is this normal?
I butchered the chamfer on the rudder… so I made a new one with some foam board I had left over from making one a @nerdnic chuck glider for the kids. (The chuck glider lasted a few days, I should call that a success.) I sharpened my box cutter blade before attempting the new rudder… that helped a lot, even though the first time I was using a new blade!
I’m done with the fuselage, and the glider front end… the front of the power pack is rough due to the melt back. I tried filling it with glue and made a mess.
Then today at lunch I tried to link my Radiomaster R88 receiver to my Radiomaster Boxer transmitter. I can’t get the led to light up, no matter how long I press the bind button…
I tried following this video in addition to the FT starting out video… no dice.
Does the motor have to be hooked up?
The speed control made the right noises when I plugged the battery in… that’s good.
I’ll be back with more… it’s nice out, but I gotta finish painting the boys new room! I never should have done the pixelated camo… it looks good, but it’s taken me FOREVER… “you’re killing me Smalls!”
