I cut the parts for the FT Mini Super Bee from Gcode I generated from Sponz's plans I edited. Everything looked good to me before and after cutting. When I glued up the naceles, one side was correct and the other was 1 FB thickness short. The notches, holes and tabs all lined up correctly.
I will print the original plans and my edited SLGs this evening and compare measurements. I can see me acicidentally moving something in Inkscape when editing, but to get exactly the same mistake on two seperate(mirror immage) parts seems to negate that possibility. I thought at first, the nacelles might be be designed assymetrically, but the difference is not mirrored. I.e., the short side is not inboard or outboard on both nacelles. They are the left side on both nacelles.
Any ideas what might cause this symptom in the Gcode or with the cutter mechanically?
