Hello FT community! Long time reader, first time poster.
I just put together an FT Tiny Trainer with the recommended power pack A, and have had a blast flying it in a local park. It has been amazingly resilient to crashes. The park where I have been flying is located on a large hill that seems to be frequently gusty, so I decided to install an A3 Pro v2 6 axis gyro to give me some more stability on the worst days. Install and setup went smoothly, and I added the included 3300uF/16V capacitor to the bind plug on my OrangeRx r620x receiver to smooth out the BEC voltage. Here's the rundown on the equipment:
- Motor - EMax - MT1806
- EMAx BLHeli - 12A
- Servos - 4x EMax ES9051 5g Servos
- Gyro - HobbyEagle A3 Pro
- Battery - Tattu 3s LiPo Battery 75C
- Receiver - OrangeRx r620x
- Transmitter - Spektrum dx6 g3
First flight: the plane flew 5 feet and the ESC browned out. Lost communication, and motor cut out. As I approached the plane, I can hear it reconnect as if I've just turned it on. Subsequent flights revealed the same result, all done with the 4 servo setup (sport wing). Dropping the A3 gyro gain to as low as 20% gave the same result at the default servo refresh of 50Hz. If I put the gyro into disable mode it all works normally, no cut-outs. Additionally, with the motor off I can get the ESC to brown out by shaking the gyro in stabilization mode. Moving the capacitor to the various ports on both the gyro and receiver does not fix the issue. The ESC hangs loose in the front of the plane, just behind the motor and is getting plenty of ventilation, and the brown out happens suddenly and early ruling out overheating.
This seems to narrow down the problem to the 1A BEC on the BLHeli. After reading from several
well written threads on this forum, I suspect that the 1A BEC is unable to handle the load when all 4 servos are twitching around to compensate for multidirectional wind gusts despite the the capacitor
helping. Some have even written that 500mA is probably closer to the capacity this ESC can handle.
Which of these solutions would you recommend:
- Get a bigger ESC - If this is your rec, which one?
- BLHeli 20A gets a 2A BEC
- HobbyKing 40A gets 4A UBEC
- other option where the rated BEC is closer to reality
- Get a dedicated BEC and battery - this seems like overkill
- Get a bigger capacitor - this seems like a bandaid solution to a larger problem
- Return the A3, noobs shouldn't use a gyro
I'd prefer to actually get this working rather than calling it quits with the gyro, and I hesitant to test the setup much more for fear of damaging my current ESC.
Penny for your thoughts, thanks in advance.
Ben
