Hi everyone,
I built a nice Aerial image and video platform on the Tarot Fy680 frame buying the motors and ESC's from buildyourowndrone.co.uk, upgrading to 11 inch props and larger 30 amp ESC's from Jdrones.
So far so good, flies so well, it's very powerful and has no problem lifting the cam and gimbal, well this compared to a phantom 1 which I crashed into the ocean
Nevertheless on a flight yesterday evening at 100 meters up the thing started conking out badly (I could see it though fpv) but luckily the APM2.6 and loiter mode managed to keep the hex on a relatively straight down trajectory and I managed a to soft land it in some bushes with no damage.
I rearmed after changing my pants and saw that one of the ESC's was spinning the motor very slowly and irregularly, kind of twitching it, very strange, like a 4 cylinder car engine only running on 3 cylinders.
So here I am, ordering some better quality ESC's and larger 700kv motors and was thinking that I would put the ESC under the props next to the motors as it would simplify the wiring on the hub but then after some googling quickly found a lot of opinions on extending the battery leads to the ESC. Apparently it's a VERY BAD IDEA due to the inductance in the wires.
At climb the copter only draws about 32 amps from the 4s so I'm not sure it would be a problem but I would very much appreciate the expertise from the wonderful folks on this forum.
Thanks a lot!
Cheers from a rainy Zürich.
Nils
Thanks a lot!
Nils
