hi, well i was working on my RCX 175mm 1806 emax, DYS SN 16A esc.. cc3d atom, 3s 1300. 5v from the PDB.
anyhow, so i solder up the quad. hooked up the cc3d atom. flashed to the latest open pilot. ( planed on flashing dronnin after i get it in the air on open pilot)..
every thing went fine till i get to motor 3 on the sliders in the ground control software.. all the motors 1,2,4 spin up at 1119, and when i slide motor #3 to 1119 i get a constant beeping.. i have no clue what that means.. do i have a bad ESC? or bad ground? im just not sure.
i made sure all signal wires were going to the right pin.. i saw no visible shorts.
no blue smoke.
i have a doctors appointment tomorrow. pain doctor, yay blah. i hope i feel well enough after my doctors appointment to figure this out assuming i can... anyhow, if you have ran into this problem let me know what you think it is.. this is a new one for me.. i am a noob tho.. just glad i felt up to working on this.. i need to get it in the air and off my work bench so i can start my next project.. im spreading my wings and i ordered a plane to fly around the yard on top of it all. laughs. and i have a Ft mini wing on my kitchen table taped to the foam board waiting for a exact o knife.
yay RC stuff.
( im gonna look into the future.. and i bet the answer will be tear it apart and re solder the ESC? i do not feel up to trying that so i figure id ask here.. but that is my next plan of attack assuming i feel good enough tomorrow after i my doctors etc. )
chris.
p.s
could it maybe the connection between the motor and the esc, cold solder joint?
the esc are direct soldered to the motors. i noticed one time the motor try to spin a bit then beeping.. then no motor movement. on repeat trys starting and stopping the sliding action.
ok bed time for me. thanks in advance guys.. with out your help id never be building these quads. im about as dumb as a box of rocks.
no blue smoke.
chris.
p.s
