Longbaorder23
Hey guys,
Been using the new DYS SN30 series ESC's on my blackout, and they work great but either after i crash or just over time, the escs seem to not be able to keep in sync. when theyre new or undamaged, their performance is flawless. but, like KISS ESC's, it seems the durability isnt very good with these. I had one ESC go bad and i fell out of the sky. replaced, and found out another one was doing the same thing too, ordered 2 replacements, one of which is a spare. Whats going on? It appears when the ESC fails, the motor behaves as if it had only 2 wires connected. The first bad ESC was so bad that it rarely (if ever) spun the motor correctly after the damage. This one though, is intermittent. It seems to start spinning fine if i give it a bit of throttle. Whats the deal? Another note, whats a good ESC alternative? running 4 cells, 1900kv motors with 6045's, at max draws maybe 25-28A. I also would require replacement ESC's to have oneshot in them. Options? Im really confused... i also bought the DYS USB linker device, but im not sure if its quite working, but is there a way to check the ESC's functionality through BLHeliSuite? Thanks!
