PHugger
Church Meal Expert
My son got me interested in what was going on over at this site he discovered called Flite Test. I've always had a hankering to learn how to fly gliders and the first time I saw DLG I knew that what what I wanted to do. I tried to be smart about it and started on the RF7 simulator. I thought I'd build a few of these inexpensive foam board plane and learn how to fly before I spent any real money on a glider. My first build was a scratch Spitfire. I spent a lot of time on it and never got to fly it for more than a few seconds. It was a bit windy the first time out and it did a perfect 270 degree loop and planted itself in the dirt. After repairs, I tried again - it would only do a left wing over and smash into the ground. It's now beyond repair. The wing is still good, but the fuselage is trash. In retrospect the Spitter was a horrible first choice. We have a soccer field nearby and this is way too small for that plane. The plane is likely too fast and my skill is so low poor that it was a waste. It I had spent a lot of money on it I know I would have felt even worse than I did.
Next I tried a speed-build FT Flyer. I spent much less time building it knowing that it's life expectancy is short. We had a beautiful day here today with light wind and it was perfect to maiden the FT Flyer. I got it in the air for a brief flight, but landed it quickly and started adjusting the Rates and Expos. I even moved the control wire out to the least sensitive hole on the Control Horn on the Elevator. I still needed a lot of trim adjustment to get it to fly straight and level with no control input. I did a lot of short flights to test each adjustment. It's now dialed in near perfectly. I used my finger to check the CG on the Spitter (not too accurate and the likely cause of it's problems), but for the FT Flyer I used two skewers and it was dead on. The plane flies great. I can hand launch it without any issues.
My depth perception on the field is as bad as it is in RF7 and I landed my plane on top of a 25' tree on my first battery. I yelled to my son - Get the Schtick.
There is a Home Depot within a few minutes of this field and I was able to get a 20' telescoping aluminum pole to extract the plane from the Charlie Brown tree. It was caught safely on the way down and never touched the ground.
I burned 5 battery on two trips out today. The plane is still flyable with insignificant damage (mostly grass stains). I would like to offer a few words of advice to others who may be as new to this as I am -
I see this as a long term hobby and I will eventually advance to my dream of flying DLGs. I don't want to spent money on store bought planes until there is a good chance that they will survive for a while. It's going to be fun!
Best regards,
PCH
- Build something small, cheap and easy (it won't last long)
- Add the wire landing gear (saves props)
- CG is VERY important if you want it to fly
- Take baby steps until it's trimmed out properly
- Buy some extra O-rings for your Prop Saver (Home Depot #13 work great)
- Getting a real plane (that you built) to fly is more fun than RF7
- Keep a long Schtick handy
Best regards,
PCH
