L Edge
These are interesting times with the new technology. The latest is the ESC that is capable of stopping, reversing direction, so now we have a method to apply negative thrust to either the prop setup or EDF's. Have a short landing strip, no need to worry if you are high, hot and/or heavy.
Running a prop the wrong direction everyone has done and really no problems. Found a source of blades that should handle my range of planes. I explored 4D flying in the past, maybe it needs to be revisited. Love to do a nose down vertical and flip the switch as it goes into reverse and see if you can do any acrobatics with it.
How about EDF's?
So I explored that area and started by taking a balanced EDF and ran it backwards. Even went to full power and I got plenty of power with a good 12 bladed 70 EDF.
Explored with a 5 bladed 64 EDF and again it's good to go. Just don't stand close while do runups.
Purchased a 60 amp reversible ESC. Beginning to convert my boneyard planes so that I can adapt it and see what transpires. The one I am looking forward is to to take my 2 EDF transport and equip it to land, reverse the engines and even back it up. Going to add a movable nose wheel so you can even turn it around.
Since I'm interested in doing sequencer programs on my DX9, set up a program where when your throttle is closed after landing, the sequencer when switched on, increases the throttle automatically for a fixed time running backwards, shuts the EDF off and gives you back control. Since each plane is different, you have to find the time and the amount of throttle that works and then you program that in.
Will keep you posted on how progress is going. Answer any questions.
How about EDF's?
