EZ Pack Plans Index
Nisar
Looks sweet! On the up side. Small planes are easier to cut than big planes!
Agree. Cutting and gluing took no time but the taping small corners is little time consuming.. Hope will figure out a easier way soon. Have to resume work on the pusher trainer and FT Mini Victor.
Nisar
Here it is! L-39
LNXMachine
Wooo! you built it already!! this looks really cool.. what are you planning to cover it with?
Not sure, I've only built a few and just left them stock. I did put some hot glue on the leading edge to try and strength it a bit.
My wife has a circuit so I could cut out some decals for it.
Cobre
25% Sparrow in the works!
The draft/hackjob version flies AMAZING!
Next steps, add 3-channel, then the Freighter pod.
Did anything come of this?
I'm wanting to get the 3ch EZ power pack, and this looks like an epic plane!
AgentC
So I fried my control board trying to re-solder wires that came loose, so need to wait until I can get a new one to carry on testing. I really don't want to buy a whole new EZ pack seeing that all the other components work, but it might have to end up that way...
Buckeye95
Greeting everyone - first time poster.
I have completed the Nerdnic F16 listed above, and am curious about converting it to RC using the EZ 2-channel pack and had a few questions:
1.) Should the CG stay the same if it is built as a chuck glider or RC?
2.) Do these models typically require the foam paper to be removed to use the RC pack? I am assuming so, since the F16 glider weight is recommended to be 37g, and the EZ flight pack itself is 20g.
3.) Is there preference for how far apart the motors should be? Is closer to the centerline better, or out towards the end of the wings preferred for better maneuverability?
Thanks for any comments. Looking forward to getting going with this to fly with my 10 y/o son.
Pete
GrizWiz
1. Yes the CG should stay where it is. If it needs any adjustment I would move it forward rather than back.
2. If you want to be on the safe side you can remove the paper. However as long as a model is efficient enough it will fly with paper!
3. I would center the motors in the open space on the backside of the wing. I am not sure however. I would just tape them in place and make adjustments as needed to get the plane dialed in.
Have Fun!
Buckeye95
Have Fun!
Thanks for the info !
Jesse Dupreez
EZ Pack Plans
Designs by me:
Includes:​
  • EZ Bip
  • EZ RazorCrest
  • EZ DLG
  • EZ F-16
  • EZ F-18
  • EZ F-82
  • EZ F-4
  • View attachment 201774
  • EZ Blackbird and SR-71
  • EZ T-38
  • EZ FW-226
  • EZ ME-262
  • EZ JU-87
  • EZ Piper Seneca
  • EZ X-29
  • EZ Snow Skimmer
  • EZ Freezer Burn
  • EZ Cessna Skymaster
Plans Here
Designs by @Addicted
Includes:​
Plans Here
Designs by @Aviator08
Includes:​
  • EZ A-10
  • EZ Bipe
  • EZ X-Wing
  • EZ Glider
  • EZ Corsair V2
  • EZ P-40
  • EZ Piper Cherokee
Plans Here
Designs by @AgentC
Includes:​
Plans Here
Designs by @SP0NZ
Includes:
EZ Intruder: Full and Half Sheet Plans
Designs by @FlyinAgain
Includes:
  • EZ Bird of Prey w/ Canard
  • EZ Bird of Prey
  • EZ Old Fogey
  • EZ USS Reliant V1.1
  • EZ USS Reliant V1
  • EZ Sophisticated Lady
Plans Here
Designs by @rickp
Includes:
  • EZ F7F
  • EZ F7F Skins
Plans Here
FT EZ Flyers 3 Pack
  • EZ Canard
  • EZ Plank
  • EZ Vee
Plans Here
I will add some pictures later
what size motor do they use, maybe i can get then on aliiexprees
