Jesse Dupreez
would thees work?7 by 16 for the 2 channel.
7 by 20 for the 3 channel.
https://www.aliexpress.com/item/400...xp_id=8a9d6fdd-046c-4fee-8b70-d3f0618389ef-19
these motor size is 7 by 167 by 16 for the 2 channel.
No I don't think so. The second ones will work but you will need to solder connectors.
im fine with thatNo I don't think so. The second ones will work but you will need to solder connectors.
Unfortunately FliteTest does not give out plans for free anymore. FliteTest also never releases plans for stem designs, that is why I made this plans index for people to find planes to build.My kids and I have been having a blast with these planes. I saw the jet pictured below on the Flitetest STEM page, but have not seen any other references or plans for it.
Is anyone aware if this is a model with plans available?
Pete
Pete
what jet is that supposed to be? I've been having a lot of brain farts lately...but it sorta looks like an F-18 crossed with an F-35.
I'd love to make a chuck glider of it as well.
Hi guys. Love this thread. It should probly be a sticky. I just got an EZ pack a while ago and made Agent Cs Bronco. It is fantastic. It kinda pained me to take the electronics out for the next plane . These little planes are alot of fun. Ive got a little son and he likes Disneys Planes almost as much as me I think so I wanted to make a little Dusty. I left all the paper on. It flies pretty good not as stable as the Bronco probly but still fun. The airfoil gauges are intended to be tacked to the table while you glue the crease with the wing upside down. Then use the other gauge for dihedral, and the backside of it works to check it in the fuse. Please ignore my sharpie paint job here. I didnt expect it to actually fly!
Thanks. I flew it again today and messed with the elevator. A little bit goes a long way. Got really lucky to get the incidence right the first time lol. Battery all the way forward and high rates btw.Looks awesome - will need to add this one to the list!
I've pushed to ~75g, but it's a brick. For me, a target weight of ~60g or below has worked best.I have become fascinated by FT EZ packs. What is the largest weight/wingspan that someone has attached an EZ Pack to?
AUW or just the airframe?I've pushed to ~75g, but it's a brick. For me, a target weight of ~60g or below has worked best.
AUW, sir.AUW or just the airframe?
AUW, sir.
Dang. I was working on a minor project in my spare time. Looks like I might have to downsize it. Sheet size would be 24X36. Wingspan around 20.8" as is.
Too big? All advice is welcome.
That looks awesome! So far, I've noticed all the EZ's I've designed (that fly well), can fit no less than 2 to a single 20x30 sheet.
Technically he is doing 2 on 1 sheet but using skins.That looks awesome! So far, I've noticed all the EZ's I've designed (that fly well), can fit no less than 2 to a single 20x30 sheet.
