F-14 Tomcat Build Guidance & Pictures
Flitedesign 3d
Flitedesign 3d
More
usaserres
First, thank you for your hard work and all those details. I am going to take on this project. Now, just one preliminary question: For the plans that are in your download file, on what size of paper should they be printed?
Thanks.
noam
If i want to use 70mm edf's will i need to resize the plans or just to leave them as they are?
Flitedesign 3d
Probably better if you upscale the plans by 5-10%. Not only because of size constraints but 70mm power system is also quite a bit heavier which might make it more difficult to hand launch
noam
I want to know if I can 3D print the wing sweep mechanism? If yes so from what metirial? PETG?
I don't really have access to a cnc machine :(
I think I may have a friend with a cnc machine but I tend ill need to make it from plywood. Will it work?
Flitedesign 3d
I don't recommend printing the carbon fiber parts as it would result in a very flexible central wing structure, even if you made it slightly thicker. Birch plywood might just work, that's what I used in the first version of the F-14, though it was quite flexible too. For carbon fiber, there are cnc cutting services available on the internet where you can order custom parts with your dxf files.
noam
Yes @tamuct01 also said that i can go to pcbways website and upload the files or, I might have a friend that has a cnc mechine so i will check with him but thank you so much🙏
Still waiting on the edf's because of the war thats happening :( but as soon as ill get them ill buid it for sure🫡🫡
