Project F-14 Tomcat
Flitedesign 3d
3d model of my twin edf f-14 is almost ready. Soon I will be making plans for it but unfortunately I can't make the first prototype anytime soon since there is no European distripution of the foam board at the time. More pictures in my media.
Edit 07.09.2021:
Plans are now available here: https://forum.flitetest.com/index.php?resources/f-14-tomcat.249/
And build guidance here: https://forum.flitetest.com/index.php?threads/f-14-tomcat-build-guidance-pictures.68210/
miraspen
If you get it to 64 or 70mm i'd be happy to help you with the prototyping. twin 90s is just not in the budget. looks good!
Flitedesign 3d
Its going to be 70 mm. I don't trust the wingsweep hinge on a heavier model :) Just need to wait and hope flite test actually gets the european distripution going soon. Here's an update on the wingbox design. The 3d model is almost complete, it only needs some internal structures on some points to make is possible to build it out of foam boad.
L Edge
Either with a potentiometer switch or normal 2 or 3 position switch with a servo slower
Would you like the throttle to control it?
Depending on radio, you can have say for instance, zero to 1/2 throttle, the wings are perpendicular at all times in mode 1.
In mode 2, if you have a graphing or mixing , you can set (I used) 1/2 throttle to full moving the wing backwards depending on the position of the throttle. So, 50% wing straight out, 60% moved back 1/3, 75% 1/2 way back so at full throttle the wing is all the way back.
What radio do you have?
Also in servo setup of your radio, you should have a speed page where you can set that servo's speed. I set the wing's movement to 2 seconds so it doesn't strain it or rip the gears like mine first did. Looks more professionable.
Flitedesign 3d
That sounds very interesting and definetily worth a try. So did I understand correctly that in mode one the wings are always facing forward as its needed in takeoff?
Flitedesign 3d
I have DX6i but I'm just about to get my fyrst fpv freestyle quad and with that I will get the frsky x9 lite (buying an used set). Im pretty sure the dx6i doesnt have such thing as servo slower, we'll see about the frsky.
Flitedesign 3d
Are you familiar with laser cut gears and external feedback servo mods? If I were doing a swingwing I'd definitely use those two techniques.
I know that it exists but I have no idea how to do it. But it sounds like a smart way to do it for sure. If you have some tutorials about it I will definitely take a look at it.
Captain Jay
Thanks I'm glad you like it! The scale of the 3d model is for 90 mm but I might draw the plans for 70 mm edf instead since propably not as many people are interested in building such big jet.
How about 2 x 64mm and 2 x 50mm. I am trying so hard to stay with 3s 2200 batteries and smaller as to not fill my house with a warehouse size collection of batteries or stepping up to the pricier 6s etc.. Also, I just order 2 of each said edf's. Lol
CampRobber
It's been a while since I've done that kind of thing. Matthias Wandel sells a program that generates gears: https://woodgears.ca/gear/index.html so you'd use that to generate matching gear forms. Then you'd import them into cad and (1) alter the small one in whatever way to mount on your servo (2) alter the large one to cut off 80% of the teeth (depending on how far you need to swing) and re-shape it into the wing root.
It depends on the servo model, but I think there are guides to modifying most of them for continuous rotation. You'd do all those steps, but instead of either setting the disconnected feedback pot in the middle or replacing it with matched resistors, you'd rewire it to an external potentiometer on the big gear.
To make it symmetric you could offset the servo to one side or the other, and have a matching idler gear next to it to move the other wing.
Flitedesign 3d
Im going to use 4s 70 mm edf's on mine as I have ordered them already and I had the battery also. Also the fact that the foam board I probably end up using is heavier than the ft foam doesn't really allow me to build in smaller size. But it is not that big of a deal to anyone to scale down the plans anyways :)
