Aviator08
Flagstaff,AZ
After watching Disney's " Planes" my step daughter asked me if I could build "Skipper". We had already built "Ripslinger" and " Dusty" and a couple other FT aircraft. I told her I wasn't sure but would see what I could do. Having recently learned some AutoCAD, it became a challenge for me to complete. One of the "must - haves" was to maintain the big round look of the fuselage; another one was to use only the materials that the FT planes use so it could be inexpensively duplicated and the third was to incorperate the "swappable power pod" . The F4U Corsair build has met those requirements and is a very scale flyer. It performs loops, rolls, and inverted flight quite well. The silhouette is easily identifiable and is fun to fly.
Have Fun and Fly Safe!
Here is a build video and test flight of the Corsair.
Prototype next to the FT P-51
CORSAIR PLANS
View attachment Corsair 4 Model.pdf ( page 1)
View attachment Corsair 5 Model.pdf ( page 2)
F4U CORSAIR SPECS.
WEIGHT WITHOUT BATTERY: 20 oz. ( 567 g)
CENTER OF GRAVITY: 3" ( 76.2 mm) from leading edge of wing
CONTROL SURFACE THROWS: 16˚ deflection - Expo 30%
WINGSPAN: 46 inches (1168 mm)
RECOMMENDED MOTOR: Park 425, 1000 kv minimum
RECOMMENDED PROP: 10 x 6, 10 x 7 prop
RECOMMENDED ESC: 30 amp
RECOMMENDED BATTERY: 2200 mAH 3s
RECOMMENDED SERVOS: (4 ) 9 gram servos
CORSAIR PLANS
F4U CORSAIR SPECS.
