I am starting this thread to develop a MAX FB gyrocopter/Autogiro with the aim that a true FB Autogiro that others can build and trim, (prior to first flight) without any maths degree or special equipment and materials.
Whilst my main experimental efforts will be in a single rotor uncontrolled head design the controlled head and the multi-rotor versions will be built and flown as well.
So far as posted on another thread I have used a Tiny Trainer fuselage and have had a few somewhat short flights to date, though one flight actually lasted a full circuit of my local field. With 3 different FB blade designs I have learned a great deal about the head design and future project direction.
I will need more engine thrust as when flying on the rotor the thrust is not quite enough to easily maintain forward flight though I have managed quite a few controlled tail first landings.
HEAD DESIGN:
To date I have been experimenting with materials, (Mostly 1.5mm 3Ply), to give the appropriate flex to allow blade incidence change as the blades flap up and down. I hope to quantify the amount of flex with a weight or torque measurement so alternate materials can be substituted for my materials. Once quantified the head design can be adapted for as many blades as I can fit, (if required).
As the head is fixed, (no control inputs), I have used a plywood platform mounted atop an Aluminium framework. The platform is fixed adjustable for pre-flight rotor incidence adjustments. The rotor shaft bearing is an Outrunner motor mounted directly to the plywood platform and a prop adapter attached to the motor shaft. The head has a plywood flapping angle plate and an Al Lead/Lag limiter bar combined with the plywood bar to which the blades are attached.
BLADES:
So far I have used 3 different sets of 2 blades and tested methods of strengthening the FB without adding CF or similar.
Each blade has an underslung plywood strip and a paddle pop stick in the upper surface of the blade with 3 screws connecting the blade. Makes blade/FB changes much easier.
Next Step:
Build a smaller fuselage or buy a larger motor. (most likely a smaller fuselage because of larger motor requiring larger ESC and Battery).
Today. Tried out the latest set of blades and managed a few "Hops" but lack of thrust caused the usual slow down and loss of control landing. Decided to build a purpose designed FB fuselage to continue project.
HEAD DESIGN:
BLADES:
Next Step:
