Today whilst I was cutting and gluing the next ordered plane I had a thought about what went wrong with my last attempt at flying the Gyro with the Teeter head. So I checked what I suspected and discovered that I had made a big mistake.
My first rotor head design was made to use blades that rotate in a CCW direction when viewed from the top. When I made my last sets of blades I accidentally made one set of blades that would work on a CW head. As I needed the CCW props for the original design I earmarked the CW set for use on the new teeter head design. I fitted the blades and adjusted the initial blade incidence angle as designed and attempted a take off, BIG MISTAKE!
The rotor head was reluctant to spin up as expected and when I finally took off the gyro rolled onto its right side and crashed. My suspicion fell upon the mechanical resistance of the teeter bar itself. I WAS WRONG!
Today I realised I had designed and built the teeter head assembly to rotate CCW.
I quickly fitted the spare set of CCW blades of the new design, readjusted the initial incidence angle to suit the new rotation direction and walked outside into the breeze to see what would happen. The difference was staggering. The rotor head started to rotate almost immediately and when a gust of wind came along the pull from the blades and the "Helicopter" noise was incredible.
Why did it make a difference? well the teeter head has an offset pivot, (Teeter), angle which is designed to reduce incidence angle as the blade rises. What I had done was to fit blades which were designed to rotate the other way. The net result was that as I tried to take off the whole disk lifted the machine with the inertia of the blades keeping the blades level but as they slowed a bit the advancing blade rose and instead of the incidence decreasing it actually increased whilst at the same time the retreating blade fell and its incidence went more negative. All of the lift was suddenly moved to the left side and therefore the whole Gyro rolled away from the lift and crashed.
I may try the teeter head again tomorrow in its current setup to see if it does actually fly and if the new simpler blade design is strong enough to support such a heavy gyro. One unknown problem identified and eliminated.:applause:
Back to the order
