danskis
I'm seriously hooked on DLG flying. It reminds me of when I was a kid and all I had to do was chuck that glider into the air. Of course things have become more sophisticated now with DLG but the feeling is still the same. First I'm not really sure where to put this as it doesn't have very much balsa in it but I figure its as good here as anywhere else. The Feather 2:
Feather² Squared Micro F3k DLG RC Glider Airplane Kit Ultralight Ultrafun (microbirds.com)
It is really a micro so I'm thinking I won't be able to throw it real hard but we'll see. The kit cost about $130 complete with receiver, servos and covering. Pretty cheap for a DLG. This is the most complete I've ever seen. It comes complete with extra micro electrical connectors, a brush to brush on epoxy, wing plans and access to a very good build video. I started on the fuselage which is just a block of roughly shaped foam and a carbon rod. You dig out a trench for the rod and gorilla glue it in. You then dig out some recesses for your receiver and battery. I haven't done it yet but your supposed to cover the fuse with carbon tow covered with epoxy (the build calls for burying the receiver and the battery). I'm waiting until everything is built, installed and working.
